SPS Motorsport
Re: SPS Motorsport
Thank You very much. We are looking for comparable solutions in the NC, NB and NA.
Best regards
Guido from SPS
Best regards
Guido from SPS
Re: SPS Motorsport
Last weekend we had another TimeAttack run, this time at the "Reisbrennen".
We had some issues with the white NA and the green NB:
The white NA got another Turbo, a Borg Warner EFR 7670. At 1.5bar the fuel pressure got to low so we have to upgrade the fuelpump.
The green NB got problems with the ignition. We have to change the sparkplugs to a higher heat value.
But the rest of our cars performed pretty well and we saw many other MX-5 on the track. We are happy to MX-5s on the racetrack.
Some impressions:
Best regards
Guido from SPS
Some impressions:
Best regards
Guido from SPS
Re: SPS Motorsport
We had a customer here for a budget turbo conversion with a TD04 turbocharger on a 1.6L engine producing 220hp. Cool and clean looking car with some nice parts installed.
Best regards
Guido from SPS
Best regards
Guido from SPS
Re: SPS Motorsport
Nice setup and very clean upgrade, it's look like stock !!!
Good job guys !!!
Good job guys !!!
Mazda 3 MPS quasiment stock
Subaru WRX Rex plus vraiment stock
Re: SPS Motorsport
Here we have one of our biggest customer projects this year. A MX-5 ND RF with a Rocket Bunny kit and turbo conversion. A stunning car...
- Rocket Bunny kit
- Work Rims
- Nankang AR-1
- SPS coilover customized
- BBR GTi turbo conversion
- Zymexx exhaust
- CAE shortshifter
- Recaro Pole Position seats
If You have questions about the car or something different, just ask me.
Best regards
Guido from SPS
- Rocket Bunny kit
- Work Rims
- Nankang AR-1
- Zymexx exhaust
- CAE shortshifter
Best regards
Guido from SPS
Re: SPS Motorsport
Yeah, very nice !!!
Re: SPS Motorsport
This year the world is celebrating 30 years of Mazda MX-5. So Mazda Germany had the idea to pay tribute by braking a record.
The idea was to drive as many corners as possible in 12 hours. The perfect job for a MX-5 NA.
So Mazda Germany came to us to get a red NA 1.6L prepared for the record. The limit was the power of the engine had to be stock.
So we installed these parts:
- engine oil cooling kit
- 6 speed transmission with gearbox oil cooling kit
- miataroadster short shifter
- Torsen-LSD with differential oil cooling kit
- SPS roll bar
- Sparco steering wheel
- Sparco Sprint seats
- Schroth racing 4-point harness
- StopTech 4-piston 286mm Big Brake Kit
- BC Racing ER-series suspension
- ATS DTC 15" rims
- Mishimoto radiator
- Competition Clutch Flywheel and Stage 3 Clutch
- custom exhaust
- custom rallye headlights
Then they set the record in the austrian alps. Mazda Germany also produced a YouTube series about that record. We are very proud to be part of that whole operation.
YouTube:
Press: http://japanesenostalgiccar.com/mazda-m ... -12-hours/
Best regards
Guido from SPS
- SPS roll bar
- ATS DTC 15" rims
- custom exhaust
YouTube:
Best regards
Guido from SPS
Re: SPS Motorsport
This is the car of a good friend of our company. The look of the car is really cool, but the engine is a tough one.
A BP block, reamed to 2 liters with an individual throttle body, race header, adjustable camshaft gears, race camshafts, revving to 8600rpm producing 230hp.
The sound the engine produces, is incredible! It screams like a race car! I think the owner, Jean Claudio Flensberg, has a good taste.
Parts:
- 2.0L reamed BP block
- ARP head stud kit
- JE pistons 85.5mm
- K1 conrods
- ACL bearings
- adjustable camshaft gears
- race camshafts
- Supertech valves with Supertech valve spring kit
- Jenvey ITB
- Racingbeat exhaust header
- BC-Racing coilover
- Nardi deep corn steering wheel
- Recaro Profi SPG seats
- Takata harness
- SPS Extreme rollover bar
- Rota Kyuasha 8x15 0mm offset
- Nankang NS-2R 195/50R15
YouTube:
Instagram:
https://www.instagram.com/naughtymiata/
Best regards
Guido from SPS
Parts:
- ARP head stud kit
- JE pistons 85.5mm
- K1 conrods
- ACL bearings
- race camshafts
- Jenvey ITB
- Takata harness
YouTube:
Instagram:
Best regards
Guido from SPS
Re: SPS Motorsport
This is one of the toughest conversions we ever made. A 2.5L V6 KL swap with an ITB. We had many issues with the car until it was ready to go on the street. But at the end we solved every problem and now the car runs fine. The block is bored from 2.5L to 2.6L equipped with Wiseco pistons and K1 conrods, main and conrod bearings are Toga high performance bearings. The head got solid cam followers with different camshaft and an individual throttle body. The engine produces 250hp with an airbox on the ITB and 300hp without the airbox.
Specs:
- 2.6L KL
- Wiseco pistons
- K1 conrods
- Toga high performance main and conrod bearings
- Catcams camshafts
- solid cam followers
- custom ITB
- custom airbox
- mishimoto radiator
- BC Racing BR-series coilover
- DIY microsquirt ECU
- Rota RKR 8x15" 10mm offset rims
YouTube:
Best regards
Guido from SPS
Specs:
- 2.6L KL
- Wiseco pistons
- K1 conrods
- Catcams camshafts
- custom ITB
- custom airbox
YouTube:
Best regards
Guido from SPS
Re: SPS Motorsport
This 10th-anniversary NB got in our workshop because on our last trackday in Anneau Du Rhin the timing belt got destroyed by some dirt of the track.
We supposed the valves also got broken because of other camshafts and higher compression, but luckily nothing else got broken.
It is a 1.8L bored to 2.0L with an ITB and very aggressive camshafts. On the dyno it produces 230 natural aspirated horsepower at 7800rpm.
Because of that power and a shorter final drive in combination with a 6-speed gearbox and a shortshifter it is really much fun to drive.
Specs:
- 1.8L BP bored to 2.0L with 85.5mm pistons
- Jenvey ITB
- Mishimoto X-Line radiator for Honda Civic
- Reverie RH carbon airbox with custom ram-air hose
- König K 5000 seats
- OZ Ultraleggera 15 inch
Best regards
Guido from SPS
Specs:
- Jenvey ITB
Best regards
Guido from SPS
Re: SPS Motorsport
This is a really nice sleeper setup. A 1.8L NA with a GT3071R turbocharger producing more than 350hp.
The owner doesn't want a rollover bar because he wants to keep the sleeper look.
Specs:
- 1.8L BP bored for 84.5mm Wiseco pistons
- K1 conrods
- ACL main- and rod bearings
- Boundary stage 2 oilpump
- ARP head stud kit
- Garret GT3071R turbocharger
- ATI Superdamper
- SPS oil cooling kit
- Skid Nation reroute kit
- 6-speed gearbox
- MiataRoadster short shifter
- StopTech BBK 280mm
- Rota Strike 8x15 20mm offset with Nankang AR-1
- CanChecked Display universal 2.8"
YouTube:
Best regards
Guido from SPS
Specs:
- K1 conrods
- ARP head stud kit
- ATI Superdamper
- 6-speed gearbox
YouTube:
Best regards
Guido from SPS
Re: SPS Motorsport
This is a supercharged NC from a good friend of the company. The car got a Rotrex C30/94 on its 2.0L installed producing 303hp and 314Nm.
Also the car got a nice look with it shiny rims and low coilover setup.
I think Kermit likes that.
YouTube:
Instagram:
https://www.instagram.com/ndi.like
Best regards
Guido from SPS
YouTube:
Instagram:
Best regards
Guido from SPS
Re: SPS Motorsport
Hey guys,
this is our second MX-5 ND. It is wrapped in british racing green and has some cool stuff installed. It is also our first car with a 200hp package with a full exhaust system including race header and software tuning.
It has also following parts installed:
- SPS circuit coilover
- StopTech 280mm 4-pistons Big Brake Kit
- Rays TE37 rims 8x16 25mm offset with Toyo R888 205/50 R16 tires
- Friedrich Motorsport exhaust system
- BBR GTi race header
- CAE short shifter
YouTube:
Best regards
Guido from SPS
- CAE short shifter
YouTube:
Best regards
Guido from SPS
Re: SPS Motorsport
3 weeks ago we took part at the German TimeAttack Finals and the European TimeAttack at the Nürburgring. Our race cars performed well, but our red ND just got a little accident. Nevertheless we celebrated many victories in different classes. It was a great season ending!
Best regards
Guido from SPS
Best regards
Guido from SPS
Re: SPS Motorsport
Long time nothing new here. So there You get a cool customer project.
This 1.6L Miata import got a turbo conversion and has still its air conditioning installed and running. The engine got forged parts and the turbo is an upgraded TD04 turbocharger. Now the engine produces 281hp at the flywheel and 362Nm/267lbft torque.
The specs:
- 1.6L B6 engine bored to 79mm
- JE pistons 79mm
- Cometic head gasket 79mm
- Molnar Technologies conrods
- ACL main bearings
- King conrod bearings
- Upgrade TD04 turbocharger
- SPS 700ccm fuel injectors
- SPS engine oil cooling kit
- Competition Clutch Stage 3
- Fender Flares
- Japan Racing JR19 8Jx15 0mm offset with 20mm spacers front and 25mm spacers rear
- Nankang NS-2R 195/50 R15 tires
Best regards
Guido from SPS
The specs:
- JE pistons 79mm
- ACL main bearings
- Fender Flares
Best regards
Guido from SPS
Re: SPS Motorsport
Very nice upgrade!
Is the gearbox strong enough for this setup?
Re: SPS Motorsport
Hi Ansyl,
thank You very much. The 5-speed gearbox, which is installed, will break, for sure. The question is when. It depends on how the customer uses his car.
Best regards
Guido from SPS
Best regards
Guido from SPS
Modifié en dernier par Guido@SPS le 21 nov. 2019 09:18, modifié 1 fois.
Re: SPS Motorsport
Hi Guido!
Thanks for your answer !
Bad news for him, not easy to drive with an egg under the throttle to limit the torque...
Are the nb gearbox stronger and ok for these numbers?
Best regards, Sylvain
Re: SPS Motorsport
Hi Ansyl,
the NB gearboxes have the same problems like the NA. The 5-speed gearbox brakes earlier, the 6-speed later. But this works for a while. It is not like changing gearbox every 6 months. They work for a longer time.
We have a customer with an 1.8L NA with a GT3071R with 360hp and a 5-speed gearbox. This works for more than one year now and he also joins track days. So it depends on, but he knows it will break some time.
Best regards
Guido from SPS
Best regards
Guido from SPS
